Buscar temas sin respuesta | Ver temas activos Fecha actual 19 Feb 2018, 22:20
Responder al tema  [ 181 mensajes ]  Ir a página 1, 2, 3, 4, 5 ... 10  Siguiente
 [TUTORIAL] Quitar Triángulo/Contador TODAS LAS ICS/JB + ROOT
Nota [TUTORIAL] Quitar Triángulo/Contador TODAS LAS ICS/JB + ROOT
SOLO PARA ICS/JB Y ROOT
Es una app que se llama [root] Triangle Away. La podeis encontrar en el market de pago o en xda o al final de este post.
- Triangle Away shows a negative counter ?
If you have a very large flash count (over 127) this is known to happen. Please confirm in download mode that you actually have that large a flash count before resetting the counter.
- After using Triangle Away I get no bootscreen at all or an error message on screen ?
Try flashing the attached "param.tar" as PDA in ODIN (no repartition!), that may clear up the issue. Samsung Galaxy S II GT-I9100 ONLY
- What about future updates and devices ?
Please read this article I wrote about this: http://www.chainfire.eu/articles/118...ay_vs_Samsung/
- On my SGS3/Note2/etc, Download Mode says my System is modified, and Triangle Away does not reset it
Triangle Away attempt to reset this status and block it from coming back, but it depends on the firmware. It does work on some (not all) stock firmwares. Resetting this value doesn't work on custom firmwares! See the post below this one for more information.
- On the SGS3/Note2/etc, System->Settings->About device->Status still shows "Modified"
This is outside the scope of Triangle Away. The "system" status is not even always resettable in the bootloader. If you are going for warranty, you need to also reflash a full stock firmware and wipe your device. If they boot up your device and find root apps, you're not going to get any warranty anyway. If you do such a full stock reflash and wipe, the "Modified" value will go away. See the post below this one for more information.
- My counter always stays at 1
Some devices/bootloaders set the counter to 1 at every boot if you are running a custom kernel or recovery. On these devices, Triangle Away may always display 1 - make sure to check the counter in actual download mode, and make sure you are running a stock Samsung kernel and recovery.
Supported devices
Samsung Galaxy S2 GT-I9100 **
Samsung Galaxy S2 SPH-D710 Epic 4G Touch **
Samsung Galaxy S2 Korea SHW-M250K/L/S **
Samsung Galaxy Note GT-N7000 **
Samsung Galaxy Note GT-I9220 **
Samsung Galaxy S3 GT-I9300 **
Samsung Galaxy S3 GT-I9300T **
Samsung Galaxy S3 AT&T
Samsung Galaxy S3 Sprint
Samsung Galaxy S3 T-Mobile
Samsung Galaxy S3 Verizon UNLOCK BOOTLOADER
Samsung Galaxy S3 Canada
Samsung Galaxy S3 US Cellular
Samsung Galaxy S3 MetroPCS
Samsung Galaxy S3 Cricket
Samsung Galaxy S3 C-Spire
Samsung Galaxy S3 GT-I9305 LTE **
Samsung Galaxy S3 GT-I9305T LTE **
Samsung Galaxy S3 GT-I9305N LTE **
Samsung Galaxy S3 Korea SHV-E210K/L/S ** DISABLE DUE TO ISSUES
Samsung Galaxy S3 Korea SHW-M440S **
Samsung Galaxy Note 2 GT-N7100/T **
Samsung Galaxy Note 2 GT-N7102 **
Samsung Galaxy Note 2 GT-N7105/T LTE **
Samsung Galaxy Note 2 SPH-L900 Sprint **
Samsung Galaxy Note 2 SGH-T889 T-Mobile **
Samsung Galaxy Note 2 SGH-T889V Canada **
Samsung Galaxy Note 2 SGH-R950 US Cellular **
Samsung Galaxy Note 2 AT&T/Canada SGH-I317/M **
Samsung Galaxy Note 2 SCH-I605 Verizon ** UNLOCK BOOTLOADER
Samsung Galaxy Note 2 Korea SHV-E250K/L/S **
Samsung Galaxy Camera EK-GC100 **
Samsung Galaxy Note 10.1" GT-N8000 3G **
Samsung Galaxy Note 10.1" GT-N801x Wi-Fi **
Samsung Galaxy Note 10.1" GT-N8020 LTE **
Samsung Galaxy Note 10.1" SHW-M480S/K/W **
Samsung Galaxy Tab 2 GT-P310x 7" 3G
Samsung Galaxy Tab 2 GT-P311x 7" Wi-Fi
Samsung Galaxy Tab 2 GT-P510x 10.1" 3G
Samsung Galaxy Tab 2 GT-P511x 10.1" Wi-Fi
Samsung Galaxy Ace 2 GT-I8160
Samsung Galaxy S Advance GT-I9070/P
Samsung Galaxy S3 Mini GT-I8190
Samsung Galaxy Grand Duos GT-I9082
Samsung Galaxy Ace Plus GT-S7500
Samsung Galaxy Ace IIx GT-S7560
Samsung Galaxy S Duos GT-S7562
Samsung Galaxy Premier GT-I9260
Various Qualcomm-based Samsung devices should now be supported as well, but I don't know which ones - please let me know!
Suspected is a large range of Qualcomm based Note and S2 variants.
** Various related models are supported depending on firmware, but only the exact model numbers listed are supported regardless of firmware version.
Whether or not Triangle Away works depends largely on your kernel. Flashing a different kernel may make it work if it previously didn't.
Esta aplicacion nos quita el triangulo asi como nos pone el contador de flasheos a 0 (el contador que sale en modo download). Ahorrandonos asi el JIG, el cual no funciona en ICS con el bootloader nuevo.
Instrucciones:
Despues de instalar la aplicacion y abrirla, Se le dan permisos cuando lo pida el superuser(PERMISOS ROOT), y pulsar en la opción "Reset counts"...acto seguido nos saldra que la SD interna esta extraida,..Salimos de la aplicacion, Nos vamos a Ajustes, Almacenamiento, he instalarla de nuevo. ( Leer atentamente las instrucciones ya que podria causar BRICK, del cual NO ME HAGO RESPONSABLE )
REPITO solo para versiones ICS/JB y ROOTEADAS.
Apta para todas las versiones ICS!!!
Funciona a la perfeccion. yo lo hice con miedo.. pero que va a la primera.
A mi de 24 a 0 en un momento... despues podeis desistalarla sin problemas ;)
Espero que os ayude como a mi ;)
Última edición por esegarry el 28 Mar 2013, 20:57, editado 41 veces en total
03 Abr 2012, 17:38
Nota Re: Quita TRIAUNGULO y RESET CONTADOR SIN JIT >SOLO ICS + RO
Gracias esegarry!
Muy buen aporte!
Te pongo la chinchetilla y le cambio el nombre!
03 Abr 2012, 18:06
Nota Re: [TUTORIAL] Quitar Triángulo Amarillo SOLO en ICS + ROOT
Como siempre un placer ;)
03 Abr 2012, 18:17
No entiendo como hacerlo podias hacer un pequeño tuto para torpes.. :P
05 Abr 2012, 01:20
Es simple..mas explicado no puedo.. Con un SGS 2 con version ICS y con ROOT, descargas la app, la instalas, la arrancas, le das permisos de root cuando salga en pantalla, y cuando tengas la aplicacion abierta pulsas en Reset Counts. Y listo. Saldra que la SD esta extraida, en almacenamiento la volvemos a instalar y reiniciamos.
Si no sabes llegar a ICS con root... Lee un poko otros post antes.
No tiene mas complicacion. Intentalo si kieres y me preguntas dudas especificas.
05 Abr 2012, 11:09
De PM, del tirón lo ha hecho. Muchas gracias :D
10 Abr 2012, 04:21
Un placerrr
11 Abr 2012, 15:17
Hola, estuve buscando lo que es el JIT y no lo encuentro...
Alguna ayudita??? :)
15 Abr 2012, 12:18
No es jit es jig. Es un error :grin:
15 Abr 2012, 12:23
Es una mini usb con unas resistencias que quitan el triangulo..resetean el contador y reviven el movil..pero con bootloader antiguo..el nuevo aun creo que nop.
La app hace lo mismo..pero en ICS
15 Abr 2012, 12:30
Jaja toda la razon..cagada tipografica mia... Ya esta corregido ;)
15 Abr 2012, 12:33
:mrgreen::mrgreen:
15 Abr 2012, 12:46
Pero y para qué sirve poner eso a cero?
Me quedé igual... :(
15 Abr 2012, 22:35
Pues en un principio por si lo tienes que llevar al SAT para que no vean que has puesto ROMs que no son "oficiales".
Por lo demás no tiene importancia.
15 Abr 2012, 22:39
ESe contador muestra las veces que has modificado el teléfono entonces si algún día te hiciera falta llevarlo al servicio técnico podían invalidarte la garantia
15 Abr 2012, 22:45
Mas vale prevenir no? Nunca se sabe ;)
15 Abr 2012, 22:47
Ajá!
Todo claro!! Muchísimas gracias!!!
Por tu respuesta intuyo que puedo poner cualquier ROM oficial?? O se considera ROM oficial a las que se actualizan únicamente por Kies??
15 Abr 2012, 23:20
Pásate por esta página http://www.sammobile.com/firmware/?page ... =1#regiona
Aquí tienes todas las Rom que hay. De todas maneras hay un post en el foro que también están viewtopic.php?t=10023
15 Abr 2012, 23:26
Solo suma cuando haces root con cf-root y si pones custom roms.. Si pones originales y no haces root con cf-root no suma..
15 Abr 2012, 23:28
OK! Gracias!!
Si lo enciendo en modo download veo que me pone que la rom que le metí el sábado de ICS es original. Pero el contador no porque había hecho CF-Root por error. OK! Entendido.
Conclusión: Si lo tuviera que mandar al SAT por lo que fuera utilizar esta aplicación para poner ese contador a 0.
16 Abr 2012, 12:36
Usuarios registrados: Angelcaro1113, Bing [Bot], Google [Bot]
