Buscar temas sin respuesta | Ver temas activos Fecha actual 23 Sep 2018, 02:19
 [ROM][AOSP-4.2.2 JDQ39][Linaro 4.7.3-toolchain](Actualizado)
Nota [ROM][AOSP-4.2.2 JDQ39][Linaro 4.7.3-toolchain](Actualizado)
[ROM][AOSP-4.2.2 JDQ39][Linaro 4.7.3-toolchain]CodefireX 4.2.2 SR13
Ir al link original: http://forum.xda-developers.com/showthread.php?t=2014430
Actualizado!!!! (Al final del post estan los links Directos a la ROM y Kernels
This is a team effort by all Team codefireX members listed below, as well as many other developers and users in the android community. The kernel is built from source inline with the ROM, and the KaMakoGeeBang kernel as seen HERE. It is non-oc due to how dangerous oc'ing these chips can be. Cpufreq is fully inline with AOSP's kernel/common, and it will be kept up to date. It has fast charge enabled by default, dynamic fsync enabled by default, a vdd sysfs interface, and uses FIOPS/Interactive by default.
The codefireX team:
synergy(e) - lead dev
Mustaavalkosta - lead dev
Michyprima - dev
Pnoire - bug tester and french translator
Rdlgrmpf - contributor
BananaGranola - contributor
Unlike with some other JellyBean roms on this forum, I believe that all users should know exactly what is being built in/for the ROM. That is why all the repos I use and maintain are available for all to see and contribute to. The codefireX source links are above the download link. Please do not ask me to include any prebuilt or proprietary applications in this ROM; I will refuse, or ignore you entirely. Using proprietary or closed source applications/ROMs is and always will be a security concern I would rather not expose users to.
Click HERE for a full cfX settings feature flowchart by BananaGranola (thank you!)
NOT a re-named CM build
Based on AOSP master (not release) with regular AOSP master merges
Open Source as all AOSP ROMs deserve to be
Easily switch between a custom and "vanilla" experience in the settings app "on/off switch"
LOTS of customization options including quick settings
Built with a custom linaro based gcc4.7.3 toolchain, strict aliasing, -O3 completely (including thumb_cflags), and other Linaro optimizations such as OOM/LMK changes. JUST TRY TO FIND A FASTER SOURCE BUILT JELLYBEAN ROM!
Lots more but I'm boring myself already
Official IRC Chan is #codefirex
Twitter Del Creador
Download Stable Releases
As of SR12.5, devices that have not updated to 4.2.2 officially, or flashed the sbl stack, bootloader, rpm, and tz separately will no longer be officially supported. If you don't know what I'm talking about, flash THIS prior to flashing and booting the ROM. Custom kernels are also no longer supported until we have 4.2.2 kernel source.
Download Nightlies
Check Nightly Status
Download BaNkS Gapps
DarkCow aka elliot.newnham for the great OP design
IOMonster
KozmikKick
Faux123
MDeejay
ShowP1984
Cayniarb
ToastCFH
Kali-
Intervigil
eXistZ
CodeAuroraForum
Bhanvidia
BananaGranola
DeamonFish
MisterSchapps
Kraizk
ALL Team Codefire members
Google
KushDeck
Aus_azn
BananaCakes
Contactwajeeh
Rafyvitto
dumpsta
cruzin_cruzin
zacgoesrawr
Zanzibar
crackajack
Zelendel
daspazz
jenkem110
Virtuous Team
Andromadus Team
CyanogenMod Team (all maintainers included)
anyone I forgot
Like my work? Feel free to buy me a beer for early morning dev HERE
LTC: LPEvPYYgHorueAitXXzRHn92TYjgfACDbY
Código:
SR13:
    Built with cfX-Toolchain 4.7-2013.2 (check toolchain changelog)
    Many small performance improvements & fixes
    Mako: no longer having init.mako.rc set gov values on boot & on charge
    Custom auto brightness values
    Notification QS behavior settings
    more translations by crowdin community
SR12.5:
    Using all proprietary files from jpq39 ota (there are a ton, I mis-spoke earlier due to an unzip segfault)
    Kernel is now the prebuilt 4.2.2 kernel. Custom kernels no longer supported until source is released
    Old devices no longer supported. If you haven't updated, read the message above the download link
    Big thanks to inhies and Roach for their assistance with the new ota
SR12.1:
    Mako: Fixed NFC app behavior
    Mako: Updated fingerprint to 4.2.2 fingerprint from OTA (no new vendor props in the OTA)
    Added back Play Store DPI Wizard options, but still using new DPI change method
SR12:
    Fully merged with AOSP 4.2.2 JDQ39 (are we first?)
    Back to zlib development branch
    Reverted power button fast torch temporarily to fix screen off problems
    Navbar auto hide handle default set to 35%
SR11.1:
    Reverted squashed CAF GPS changes
    Reverted zlib development branch merge (should fix stability)
SR11:
    Mako: globally optimized for cortex-a15 (this krait chip is closer to a15 than a9, and this yields a very slight performance improvement)
    New DPI change method persists on new flashes, and doesn't affect Play Store
    Added Quick Record tile (****ty images right now - longpress to record)
    Interface: Buttons: Allow using torch on power longpress with screen off
    Interface: General: Allow disabling low battery notifications
    System : Performance : Memory Management: Add swap option for low ram devices with a swap partitioned sd card
    zlib merged with upstream development branch
    Now tracking CM-10.1 Browser
    Now tracking CM-10.1 Calculator
    Fixed keyboard sound preference behavior
    Tons of misc fixes from the AOSP
    Many other small fixes and optimizations
    More translations from the kickass crowdin community <3
SR10:
    Fixed games (reverted a small zlib optimization)
    Fixed strange bluetooth audio (reverted a bluedroid commit)
    Since SR9, backuptool now works - no need to flash gapps if dirty flashing
SR9.1:
    Really fixed kernel stability
SR9:
    Keyboard bug really fixed
    Lockscreen now uses stock behavior by default
    Navigation bar auto-hide setting & qs tile
    Lockscreen allows 7 targets on all devices
    National data roaming fixed
    Issue with ringtones missing fixed
    A ****ton of new optimizations and code cleanups - check bitbucket if you want to see everything done
    Mako: now building the custom kernel linked above inline
    Mako: using more performance oriented mount flags
Link de Version: SR13
(1) Franco Kernel r90 (Yo estoy usando la r90 y va bastante bien por ahora, cuando pueda subo capturas)
Ademas les dejo el Francokernel updater 8.8.4 Para cambiar los voltajes y esas cosas :-)
Van a ver que dice para el franco r83, pero funciona igual. Ademas ACA el link para saber que chip tienen.
Código:
https://docs.google.com/spreadsheet/ccc?key=0ApWa88wuiQozdFJidTJHeXpJcHpaTUJnZVRRLTVGdHc&usp=sharing#gid=0
(2) Kernel Harsh Harsh.16.2.13
(3) Kernel Motley Motley Build 37.zip Motley Build 39.zip
Código:
Para usar el Kernel Motley, primero tienen que instalar la version 37, y despues de reiniciar, pueden instalar la 39
Phone: LG G2 (32GB) Android: 4.4.2 ROM: LamHoang G3 2.2
Tablet: Google Nexus 7 (32GB WiFi) Android: 5.0 ROM: Stock
Última edición por kurko1992 el 02 Mar 2013, 19:02, editado 3 veces en total
09 Feb 2013, 02:37
Nota Re: [ROM][AOSP-4.2.1][LINARO][4.7.3-Toolchain] OFFICIAL code
Ahora, este es el kernel que estoy usando con esta ROM, hay varios, mas abajo voy a dejar los links.
Kernel Harsh:
harshkrnl-nexus4mako-Jan-28-LOW, como dije esta es la version que estoy usando yo, no es la ultima. Abajo dejo los links, con la ultima version hasta el momento, y otro con todas.
Ultima version: harshkrnl-nexus4mako-Feb-05
Todas las Versiones
Web Oficial Del Kernel Harsh
Otros Kernels para el Nexus 4:
Franco Kernel:
Web Oficial Del Kernel Franco
Trinity 4 Inception:
Web Oficial Del Kernel Trinity 4 Inception
Faux123:
Web Oficial Del Kernel Faux123
Hay uno o dos mas, ademas del Kernel que viee con la Stock, pero estoy son los mas conocidos creo.
Saludos ;)
PD: de yapa, dejo unos ScreenShots de mi telefono, y 2 zips, uno con varios fondos para sus telefonos y otro con un pack de iconos que me encantaron :D
Imagen Imagen
Imagen Imagen
Fondos
Iconos
09 Feb 2013, 03:08
Gacias compañero. Yo ando probando la Apocalyptic Rom que es producto nacional y trae cantidad de personalización. Y le tengo el ojo echado a unas cuantas, hay una que da en el antutu más de 20.000 sin overclock. Y probando un kernel que aún está en fase de testeo. Cuando tenga más datos os lo traeré ;)
Web Elitemovil: http://www.elitemovil.com.es/
10 Feb 2013, 09:26
Hay tantas q lleva su tiempo probarlas.
Yo me quedo con esta y aca abajo te muestro la razon del por que:
Y esto deapues de una sola carga.
Enviado desde mi Nexus 4 usando Tapatalk 2
10 Feb 2013, 09:38
Me la apunto entonces :D
10 Feb 2013, 10:40
Usa el kernerl harsh 28low. Es el que estoy usando yo. Si tenes problemas proba el 28 comun que tambien esta en el primer post o sino fijate con el ultimo.
Saludos, espero tus comentarios.
10 Feb 2013, 11:37
por cierto, nueva versión de la codefire ;)
10 Feb 2013, 12:20
Es verdad, salio las SR 11, no me diste tiempo para llegar a casa y postearla como la gente, jeje.
A mi me va tan bien la 10 que no quiero cambiarla, jajajaja.
10 Feb 2013, 16:45
Nota Re: [ROM][AOSP-4.2.1] CodefireX (Actualizado)
Despues de probar un par de horas la version 11.1 con el mismo kernel que tenia en la 10, me da ka sensacion que internet no funciona tan bien como antes, la voy a probar unos 2 dias para ver, despues paso el informe :-)
12 Feb 2013, 22:28
Yo ando probando el kernel de Elitemovil y un proyecto de ROM suya y va fenomenal, pero todo stock. Todavía es beta, cuando haya algo más concreto lo traeré ;)
12 Feb 2013, 23:08
Bienvenido sea :mrgreen:
Yo puse este solo porque es el que estoy usando, no me gusta andar poniendo cosas que no probe yo mismo.
Y hablando de todo un poco, volvi a la version 10 y ya noto la diferencia,la senial de internet esta a full todo el tiempo. Internet anda mas rapido.
Voy a dejar esta por ahora.
12 Feb 2013, 23:12
Salio la version 12.5 que seria el Android 4.2.2, no es el 100% oficial todavia, maniana desde casa posteo los links y como instalarla :-D
16 Feb 2013, 20:12
Nota Re: [ROM][AOSP-4.2.2 JDQ39][Linaro 4.7.3-toolchain](Actualiz
Actualizado el Post a la Version SR13!!!!!!!!!!!!!!!!!!!!!!
02 Mar 2013, 19:05
Dejo el funcionamiento de la ROM despues de su primer ciclo de carga.
CodefireX: SR13, Kernel: franco r90, Chip: Nominal (con los voltajes que recomiendan) y estuve toqueteando con el franco updater y creo que le puse los colores que recomienda el programa y no me acuerdo si algo mas.
Como pueden ver, en las primeras foto la NavBar esta en rojo y despues en una especie de turquesa, pero es la misma carga, me gusta andar tocando esas cosas
04 Mar 2013, 16:22
Voy a dejarte los míos en el hilo de Elite. Un saludo ;)
04 Mar 2013, 21:16
Espero para hacer la comparación :lol:
Sent from my LG Nexus 4 using Tapatalk 2
04 Mar 2013, 21:19
Usuarios registrados: Bing [Bot], Google [Bot], Google Feedfetcher, Majestic-12 [Bot]
